Is it possible to have one tab on the XP taskbar for each document that is open in Atlantis?
(I know it is nice to have all the tabs in Atlantis and for Atlantis to have only one tab on the XP 3taskbar but sometimes I need to work in a different way.)
How get one taskbar tab per document?
Sorry, but Atlantis does not display its open documents in the Windows Taskbar. The only way to have multiple Atlantis buttons in the Windows Taskbar, is to launch multiple instances of Atlantis (by clicking the Atlantis shortcut multiple times), and open a different document in each instance of Atlantis.
Can I force the sort of behaviour you describe by setting an option which will only allow a single instance of Atlantis to open onky one document?admin wrote:Sorry, but Atlantis does not display its open documents in the Windows Taskbar. The only way to have multiple Atlantis buttons in the Windows Taskbar, is to launch multiple instances of Atlantis (by clicking the Atlantis shortcut multiple times), and open a different document in each instance of Atlantis.
