Save and Save as
Save and Save as
This may seem a silly question to most, but what is the difference between save and save as in saving a document? they both seem to do the same thing.I cannot find it in the help.
Re: Save and Save as
The "Save As" allows to save the document under another filename, or change document format (RTF, COD, TXT) for the existing document.
By the way, every time you "save" a newly created document, the "Save As" command is automatically executed because you should specify a filename for this new document.
