A Formatting/Replace (Ctrl-H) Question
Sarcastikus
Post by Sarcastikus »
Hello,
I found a reference to my question in a post from several years ago, but in case things have changed..........
Is there a way to reformat a text such that I could make all the numbers, or a particular word or character in a text bold, or underline it, etc. by using Replace (Ctrl H) function? Having to go through a lengthy text and replace each individual occurance of a character, or characters, manually is a very time consuming process.
Thanks!
Hard work often pays off after time, but laziness always pays off right now.
Re: A Formatting/Replace (Ctrl-H) Question
Sarcastikus wrote:Is there a way to reformat a text such that I could make all the numbers, or a particular word or character in a text bold, or underline it, etc. by using Replace (Ctrl H) function?
Greetings--
Use Ctrl+F, enter your search string, then click "Find and Select All".
When all occurrences are selected, you can format them all together in any way you like (bold, underline, etc).
luha
Post by luha »
So when I want to reformat all numbers, all I have to do is
Use Ctrl+F, enter «1», then click "Find and Select All" and reformat the 1's
Use Ctrl+F, enter «2», then click "Find and Select All" and reformat the 2's
Use Ctrl+F, enter «3», then click "Find and Select All" and reformat the 3's
and so on.
Is there a better way to do it - or can you make a better way?
mvh
Sigurd Hasle
Re: A Formatting/Replace (Ctrl-H) Question (2)
luha wrote:So when I want to reformat all numbers, all I have to do is
and so on. Is there a better way to do it - or can you make a better way?
Hi, again!
You have a small button to the right of the "Find" box (see illustration below). Click that button and choose "Any digit". Then press "Find and Select All".
luha
Post by luha »
WOW! This program is even better than I knew. I have two favourite fonts that are almost equal, but I like to use the letters from one and the numbers from the other. Now this will be a piece of cake!
mvh
Sigurd Hasle
Sarcastikus
Thanks Robert!
