Columns
medion
Columns
Post by medion »
I have searched the forum but cannot find the answer to my question.
Is it possible to show page margin borders when using columns ? (column borders) :roll:
Thank you.
Sorry, Atlantis does not display column borders.
Re: Column "borders"
medion wrote:Is it possible to show page margin borders when using columns ? (column borders).
Greetings--
Have you tried switching on the "Line between" option in the "Format | Columns" dialog?
medion
Thank You
Post by medion »
Thank you Robert.
I just tried this but I was hoping for the lines to be there during writing.
Many thanks.
Re: Column "Borders" (2)
medion wrote: I just tried this but I was hoping for the lines to be there during writing.
Greetings--
The "Line between" option is off by default. But you can always switch it on from the "Format | Columns" dialog.
Also note that a separating line will appear only when you have put a section break in the first column and you have started a new column.
