Couple of Questions
Guest
Couple of Questions
Post by Guest »
How do I add a dictionary to Atlantis for spell check. Also how do I configure it to ask me if I want to save a document when I close the program. Thanks.
You can add new dictionaries to the Atlantis spellcheckers through the "Tools | Options... > Spellcheck > Spellcheckers & Dictionaries..." dialog.
By default, when you close Atlantis it suggests to save unsaved (modified) documents. If your Atlantis does not suggest to save documents, this means that you have instructed Atlantis not to suggest to save modified documents. Please choose "Tools | Options...", then click the "Optional Messages..." button on the General tab, and make sure that the following optional message is enabled (checked):
Optional messages.gif (7.53 KiB) Viewed 4459 times
