Atlantis Toolbars: Mimic The Word Look
Guest
Post by Guest »
When you are finished, save your new INI file. Use "Tools/Option/Load From File" to activate.
If there are any problems, please reload your original INI file. You did back it up, right???
WORD 95 TOOLBARS: Replace only these settings. Back-up your INI file first!
[\Software\Rising Sun Solutions, Inc.\Atlantis.1_x\Toolbars\STANDARD]
Visible=1
Visible_Preview=0
Commands=0000006400000078000000B47FFFFFFF0000011800000122000003207FFFFFFF00000D5C00000D0C00000D20000002BE7FFFFFFF00000F0000000F147FFFFFFF00000E38000013EC7FFFFFFF00001C200000101800003CF000000E10000017707FFFFFFF000325147FFFFFFF000186A000018B0000001877
AlternativeCommands=00000064000000780000008C000000A0000000DC000000CA000000CD000000E60000010400000140000001317FFFFFFF00000F2800000F3C00000C8000000D347FFFFFFF00001B5800015F9000015FA400015FB800015FCC00015FE07FFFFFFF0000028000000281000186E67FFFFFFF00001877
[\Software\Rising Sun Solutions, Inc.\Atlantis.1_x\Toolbars\FORMATTING]
Visible=1
Visible_Preview=0
Commands=0003309A00033C8400033CE87FFFFFFF00002F5800002F6C00002F80000002C07FFFFFFF00002378000023790000237A0000237B7FFFFFFF0000246900002468000023A00000238C
AlternativeCommands=00002F8100002F8200002F8600002F8800002F7600002F8A00002F8B7FFFFFFF0000302000002FBC00002FD000003034000030480000305C000030707FFFFFFF0000242C000024180000241B0000241E000023A00000238C000023D2000023B4000023C87FFFFFFF0000243600002437000024387FFFFFFF00002EE00000232800002440000024540000245E7FFFFFFF
WORD 97 TOOLBARS: Replace only these settings. Back-up your INI file first!
Visible=1
Visible_Preview=0
Commands=0000006400000078000000B47FFFFFFF0000011800000122000003207FFFFFFF00000D5C00000D0C00000D20000002BE7FFFFFFF00000F0000000F147FFFFFFF000011BC000013EC7FFFFFFF0000028000001C200000101800003CF000000E107FFFFFFF00001964000017707FFFFFFF000325147FFFFFFF000186A000001877
Visible=1
Visible_Preview=0
Commands=0003309A00033C8400033CE87FFFFFFF00002F5800002F6C00002F807FFFFFFF00002378000023790000237A0000237B7FFFFFFF0000246900002468000023A00000238C7FFFFFFF000002C0000002C1
