I tossed together the included template, "Novel Manuscript," as a guide for anyone involved with book authorship. I place it in the public domain, and anyone who wants to use it as they see fit, including placing it in the set of templates for Atlantis Word Processor, may do so.
GOOD NEWS: When this template is loaded into Atlantis then saved as a Word 97/2000/XP/2003 doc, the resulting file will display properly in Word 97. Since I don't have newer versions of Word, I cannot perform the test any further.
BAD NEWS: When this template is loaded into Atlantis then saved as a Word 6.0/95 doc, the resulting file will crash in Word 6.0, and display improperly in Word 97. Since I don't have other versions of Word, I cannot perform the test any further.
Template: Novel Writing
A fix will be included in any next official build or release of Atlantis. Thanks.
Guest
** UPDATE * UPDATE * UPDATE * UPDATE * UPDATE ***
Based on the admin's explanation of Page Settings
elsewhere in this forum, I hereby submit this new
version of the Novel Template. I've made a couple
of adjustments concerning Header and Footer. This
new version should open properly, with the top of
the document's page visible on the screen. Thanks
again to admin for help in solving the situation.
- Novel Manuscript-Public Domain.zip
- (1.24 KiB) Downloaded 688 times
