Default opening at 75%
Laren
Post by Laren »
I'm using an 800x600 screen and would like Atlantis to open at 75% by default rather than 100%.  Can this be done?
Re: Default opening at 75%
You should<br><br>a) open your default document template (as a rule, "Normal") - use the "File &#124; Document Templates",<br><br>b) change the zoom (use the "Zoom" toolbar combo box),<br><br>c) save your template (Ctrl+S).<br><br><br>For more info please click here.
