I would like to know have you changed anything in the way Atlantis displays text on screen (or the way it interacts with the display driver), because i started having problems with newer versions that are not present in Nova.
My display becomes garbled and I have to reboot in order to be able to work again. This only used to happen with M$ Word.
Also, don't freak out about this, I'm pretty sure it's a problem with my graphics card, just wanted to know if there was some major change in the coding that might trigger this behaviour.
Display problems/question
Re: Display problem
Greetings--
Most likely this has nothing to do with Atlantis indeed.
Display problems are best addressed by updating the display driver.
Unless it is a hardware problem.
In which case you'll have to buy a new grahics card.
Guest
I understand this sounds weird, and you feel that it is not a problem with Atlantis, but it may be one of the newer functions.
And the problem does not occur always, it's a bit random but mostly when I scroll through a document.
With Atlantis Nova though, there is no such problem at all !!!
That is what is odd about this whole thing, and what made me think there might be a change in the programming.
Anyway, great job on one of the best text processors out there
