Auto word Complete
Guest
Auto word Complete
Post by Guest »
Hi, On the auto complete of words feature, on the pop up box there is sometimes 10 words, and if it is the bottom one I have to scroll with the down key to the bottom. Would It be possible for you to loop this feature so I only have to press the up key once to get to the bottom word?
Carl
Carl
Whoops
Post by Carl »
I am the guest above, I forgot to log in :oops:
If you mean the Power Type suggestions, the popup list never includes more than 6 suggestions for English texts.
Note that you can press the End, Home, Pg Up, and Pg Dn keys to navigate through the list of suggestions.
The Up and Down cursor keys will be "looped" in the Power Type popup list of suggestions in Atlantis 1.6.1.
Carl
Post by Carl »
Thanks!!
