Margin adjustments
John Stafford
Margin adjustments
Post by John Stafford »
Hi. I was wondering if a new feature could be considered for margin adjustments. Would it be possible to adjust margins separately on each page. For example, I often print where the first page needs a large top margin in order to accomodate a letterhead, but I want successive pages to return to the default top margin.  Typically one would use delay/suppress codes for this but sometimes just manually adjusting the margin grid line is adequate (as in WordPerfect. It's a real convenience. :)
Re: Margin adjustments
Such tricks require support for so called sections.
