I had Altantis minimized in the tray.
After a while I started to have problems copying and pasting in other applications.
When I opened C:\WINDOWS\SYSTEM32\clipbrd.exe it was "eating" 90+% of cpu. I had to kill it.
I stared to close applications to see which one is causing this issue.
Once I closed Atlantis, the clipboard started work again.
Any ideas? Is it bug?
Thanks
Shpiz
Clipboard out of memory
clipbrd.exe is a Windows utility that has nothing to do with Atlantis.
If the "Tools | Options > Edit > Clipboard History" box is checked in Atlantis, it collects all the clips that go to the clipboard. If you place big pictures onto the clipboard or other big clips, this might slow down your computer. If it is your case, please uncheck this box in Atlantis.
