Pasting Produces "Squiggly" Grey Underlines
acant05
Post by acant05 »
I am trialing Atlantis (ver 1.6.0.1) and am well pleased except for 1 problem. When I paste an outline from NoteMap 2 all text has "squiggly" underlines; when same outline is pasted into MSWord this doesn't happen. Also, when the outline is 1st pasted into MSWord then into Atlantis (from a copy in Word) the "squiggly" lines still appear. Can anyone give me a solution for this problem?
Thanks.
Blessings,
Al Cantley
If the color of this underline is navy, it indicates that you do not have the spellchecker in your Atlantis for checking the underlined text.
Please right-click any underlined word. If the context menu says "No spellchecker for <language>", there are two possible reasons for this. First, you have not installed the Atlantis spellchecker for the language with which the pasted text is marked. In this case, please go to the Downloads page of the Atlantis site, then download & install the required spellchecker. Another possible reason is that the pasted text has been marked with a wrong language by the source word processing application. In this case, please select the underlined text in Atlantis, choose "Format | Language...", and specify the proper language for the selection.
Click here for more information on the spellchecking in Atlantis.
acant05
Post by acant05 »
Thanks, that took care of thr problem.
Blessings,
Al Cantley
