headings setting
Andremusic
headings setting
Post by Andremusic »
I was wondering about the Headings option in the Control Board. After finishing a chapter, I collapse the headings that I don't need to see anymore. I have 3 levels within each chapter, closing them keeps everything clear. However, after closing Atlantis and opening it again later, all the Headings are expanded again. Would it be possible to save the situation so that everything is exactly the same as I saved it?
Best regards,
André
The problem is that Atlantis cannot save such nonstandard information to DOCs. Atlantis also could not store this information in any other place than the document file (for instance, in Registry). Every document would require a separate key in the Registry. If your document contains 100 headings, Atlantis would need to store the full text of all headings plus the "collapsed/expanded" information (this would take a lot of space in the Registry file). But even this would not be a completely reliable way because two headings might have identical text, and it might be impossible to say which item in the Registry corresponds to which heading in your document.
