The program freeze
Flibustier
The program freeze
Post by Flibustier »
When clicking Help/ about Atlantis (to check version), the program freezes totally on my computer. Any reason for this? It worked perfectly in the old version, but I guess this is a bug...? Ctr+Alt+Del is the solution for now.
Flibustier
Well, it doesn't freeze but...
I just found out that I had to click within the graphic showing the version, and it dissaperars.
The program works fine, but a "Klick to close this information" could help for unfamiliar users.
Re: Well, it doesn't freeze but...
Flibustier wrote:I just found out that I had to click within the graphic showing the version, and it dissaperars.
Greetings--
When any window seems to be frozen under Windows, always try the "Esc(ape)" key before you do anything rash like "Ctrl+Alt+Del".
The Escape key will very often get you out of trouble. :)
The "Help | About..." dialog of Atlantis 1.6 will have a less confusing design:
