Is there a way to turn of the insert/overwrite option? For some reason, I find myself overwrite so many times while what I really wanted was to insert some text. I know that I probally hit the insertkey on my pc and I have to hit it again, but the fact is that I never use the overwrite option. How can I turn off the overwrite option completely?
André
insert and overwrite...
Andremusic
- Contact:
Andremusic
- Contact:
You are right. The new build includes a fix. Thanks.
Andremusic
- Contact:
Andremusic
- Contact:
The "hot key" fix should work in the latest build. First please make sure that the "Hot Keys" dialog says that no hot key assigned to the Ins/Ovr command (as on the attached screen capture). Also are you sure that you downloaded the latest build (7c6):
http://www.atlantiswordprocessor.com/en/html/atl10_beta/atlantis15en_4_7c6.zip
The "Save cursor position" feature should work too. Note that it applies only to RTFs and CODs.
- Image.gif (7.24 KiB) Viewed 6915 times
There was another hot-key-related bug. If you removed the original hot key but assigned another hot key instead, both the new and the original hot keys still worked. Please download the latest build.
Andremusic
- Contact:
