Congratulations (and some comments)
luha
Post by luha »
Congratulations! Atlantis is now even better!
Luckily, I don't have the problem with the icons mentioned by some others.
In the last version of Atlantis, if I tried to do certain operations with the Clippy Bank and the Clip Library, the whole program would crash - now that problem is gone, too!
I have just one wish left: When I want to insert a symbol the preview window is small and the symbols are tiny. Could you make them bigger, please?
mvh Sigurd Hasle
The new build displays a bigger version of the “Insert | Symbol…” dialog under 1024x768 and higher screen resolutions.
luha
Post by luha »
Thank you very much! Now it is much easier to see what I insert.
mvh Sigurd Hasle
