Outline
andre
Outline
Post by andre »
Hi!
I know that in the update, Atlantis will have an outline future and I really love that! It is a great option for my writing, but I was wondering if there will be an option to view the outline in the normal way (on the left vertical), as well at the bottom at the screen in a horizontal way. This will give a more natural feeling for the development of a story-line from start till end. Is it possible also to drag the outline parts to other positions and with that, their contents?
Thanks for a great program!
André
Re: Outline Feature
Greetings–
You will be able to drag & drop “Headings + associated paragraphs” and change their position in the document structure. You will also be able to promote or demote Heading levels with drag & drop. For example, Heading 1 paragraphs can be dragged to become Heading 3 paragraphs. And vice versa, of course.
The document outline will only be available in a vertical version. This is the natural structure of all documents.
