Margin measurements Imperial/Metric
I'm puzzled. Atlantis seems to have unaccountably changed my margin measurements from Imperial to metric and I can't find how to change the measurement system back! There doesn't appear to be anything in the help files,
Re: Measurement System
Greetings--
Try Tools | Options > Measurement system (General tab).
That's great! Many thanks. How the devil did I miss that? Too much dependence on index searching in the help files!Robert wrote: Greetings--
Re: Measurement System (2)
Greetings--jamesfol wrote: That's great! Many thanks. How the devil did I miss that? Too much dependence on index searching in the help files!
As a rule, the various Atlantis options can all be accessed from the Tools menu.
If the area of concern is not directly available as a separate menu item (like AutoCorrect Options or Hot Keys), it will always be found under Tools | Options.
