Loss of Cut and paste
Bob_E
Post by Bob_E »
I just started using this new writing program. I do like it very much. But as an old-timer, I must have a very steep learning curve. I previously had Cut and paste as a working function. Now , when I go to paste something from another source the all the applicable boxes are grayed out. I obviously did something, but  I can't find a way to enable that function. I write a twice weekly newsletter and this program is the best I have used yet. Thanks<br> ???
Re: Loss of Cut and paste
The Copy and Cut commands are disabled when there is nothing selected.<br><br>The Paste command is disabled when the clipboard is empty, or contains information in unsupported format.
