Short cut key to change between languages
abdobe
Post by abdobe »
I use Atlantis mainly for translation of letters, documents and so on.
This means that I have to change between languages within the same document. Atlantis is a great program for such work, but if I could choose from the upper shelf, I would love to change between language coding with a short cut key, instead of using the mouse.
It's no good idea to change the keyboard language, since I prefer to use one keyboard setting only.
(Please, make tables work in this program soon, and you have everything for everybody.... almost).
Missing feature:
Short cut key for language coding.
abdobe wrote: I use Atlantis mainly for translation of letters, documents and so on.
Missing feature:
Greetings--
1. Click Tools | Hot Keys…
2. Highlight the Format category on the left.
3. Scroll down the Commands box on the right.
4. Highlight the Language or Default Language icon/command.
5. Assign any available keyboard shortcut to it.
6. When you use this assigned shortcut and bring up the Language or Default Language dialog, a history of languages already used is displayed at the top of the list. Use the arrow keys to scroll up or down the list and highlight the required language coding.
7. OK out of the dialog.
abdobe
Post by abdobe »
Missing feature:
Greetings--
Great!
Thanks Robert. This works fine for me. I did the big mistake to believe that I could assign a short cut key assigned by my self, without choosing it from the pick list. Now F4 does the job.
Re: Short cut key to change between languages (2)
abdobe wrote: Thanks Robert. This works fine for me. I did the big mistake to believe that I could assign a short cut key assigned by my self, without choosing it from the pick list. Now F4 does the job.
Greetings--
You can assign keyboard shortcuts in 2 different ways:
1. Click the 3 dots button to the right of the Hot Key entry box and pick a shortcut from the list. Note that this list does not include all possible key combinations.
2. Alternatively, you can click in the Hot Key entry box, then type any combination of keys. If the typed keys are already assigned to a different command, you will get a message asking you if you want to reassign them to the new command or if you'd rather keep the old association.
