Toolbar fonts and sizes
bachvoyager
Post by bachvoyager »
:lol: First I praise Atlantis - it is the best $30 I could have ever spent to get away from my MSWord 2000, which is NOT compatible with Windows XP. I really love Atlantis.
My question is this: how do I change the fonts and sizes of the toolbars? Not the documents - I have no problem there. On the advice of several authoritative geek and nerd sites, I have changed the resolution of my computer from 800x600 to 1024x768, since so many websites have gone to the latter resolution. I have had no problem changing the font sizes IE, or Mozilla, or Mozilla Thunderbird (e-mail), using "Display" in the Control Panel, but I cannot do the same with the toolbars in Atlantis. As it is, the font is too small for comfort.
Any help with my long-winded question, and I will be so happy. :lol: Gareth P.
bachvoyager wrote: My question is this: how do I change the fonts and sizes of the toolbars? Not the documents - I have no problem there. On the advice of several authoritative geek and nerd sites, I have changed the resolution of my computer from 800x600 to 1024x768, since so many websites have gone to the latter resolution. I have had no problem changing the font sizes IE, or Mozilla, or Mozilla Thunderbird (e-mail), using "Display" in the Control Panel, but I cannot do the same with the toolbars in Atlantis. As it is, the font is too small for comfort.
Greetings--
By font size of the "toolbars", do you mean font size of the toolbar tooltips?
Or more exactly, do you mean the font size of the text on the title bars or on the menus?
If you mean the title bars or menus, the font size can be adjusted through the Windows Display Settings. Simply right-clkick an empty spot on the Windows Desktop, then select "Properties" on the menu.
Hope this helps.
