Are there any MOVE [Word? Line? Marked Block?] commands in Atlantis?
I have a feeling they ARE there, but I can't find them.
Any help will be greatly appreciated.
GOOD FORTUNES! dave miller
MOVE Commands?
Re: Move commands
Greetings--
Use mouse and drag & drop.
Here is from the Atlantis Help:
With Drag & Drop you can move the selected text to another location within the document.
To move a text fragment,
select this fragment,
place the mouse pointer over the selected text,
hold down the left mouse button, and move the mouse,
release the mouse to drop the text to a new location, or press the Esc key to cancel this operation.
If you wish to duplicate the selected text (to copy it to another location), hold the Ctrl key while dragging.
Note. Drag & Drop operations are allowed only if Enable Drag & Drop is checked on the Edit tab of the Tools | Options... dialog.
The Atlantis help also has a topic on "Working With Column Blocks" ("Editing Documents"). Please look it up.
Note that all these operations will be even more practical in the next release of Atlantis.
