Ocean Mind won't open a 'doc' by double clicking
Guest
Post by Guest »
I've been using Nova for some time and decided to give Ocean Mind a try.
If I click on a *.doc, Ocean Mind starts, but tells me it cannot open the file. However, I can open the file from the file menu. Has anyone any idea why this is happening?
Re: Ocean Mind won't open a 'doc' by double clicking
Anonymous wrote: I've been using Nova for some time and decided to give Ocean Mind a try.
Greetings--
This should not be happening.
Have you tried opening it by drag & drop from Windows Explorer?
What happens then ?
Is Atlantis Ocean Mind associated with DOC files on your system?
If your problem documents are not confidential, could you please zip and send one of them to comment@rssol.com ?
Thank you very much in advance.
Most probably that Atlantis Ocean Mind is wrongly associated with the .doc file extension. Please choose the "Tools | File Associations" command of Atlantis to associate it with the .doc file extension.
Guest
Post by Guest »
I found that it was the same with 'wri' and 'rtf' files, so I removed the associations then remade them, and all is OK now. Thanks.
