The way e-mail is handled in Atlantis is very pleasing and simple... when it works. On one of my machines, it works just fine and successfully attaches the relevant document to a message in Thunderbird. Unfortunately it doesn't do this on my other machine. I have no idea why, as I can't really see any major differences in the setup.
regards
Martin
Re: Email Client Problem
Greetings--mcleaver wrote: It is installed as default and works in Firefox, but not in Atlantis and - now I find out - not in e.g. explorer either.
If you have problems with Explorer, it is to be expected that you will run into similar trouble in Atlantis. Atlantis needs to be able to rely on a working installation of the Windows Explorer and the related emailing functions. Apparently your default email client is not working correctly with Windows. When it does, you will be able to send messages from Atlantis.
