Error when Atlantis starts
I downloaded and installed the shareware version of Atlantis but when I try to run the program I get a "Kernel32 page fault" error and the program terminates. This hasn't happened to me with any other program for years. I use Windows 95, with the Service Pack and new Kernel32 installed, 128 mb RAM, about 80 mb Ram free when I run the program, and the newest comctl32.dll.<br><br>Any suggestions?<br>
Re: Error when Atlantis starts
Do you have MS Internet Explorer 4.0 (or higher) installed? If you have not, I suggest to install MS Internet Explorer 5.x (it updates the system libraries). It is very probably that this would solve the problem.
