Reveal codes in docs?
Overcast
Post by Overcast »
Hello,
Is there an equivalent to WordPerfect's Alt-F3 command, which reveals formatting codes in documents?
Thank you for your help.
Regards,
Overcast
Atlantis Ocean Mind 1.5.3.1 - Registered
I am sorry but Atlantis does not have such a feature. But you can always choose the "Format | Font" and "Format | Paragraph" menu commands if you need information about the formatting of the selected text.
Alan
Post by Alan »
You might also use Show special symbols to see such charaters as the blank space, tabs, and paragraph symbols.
Overcast
Post by Overcast »
Thank you for your suggestions.
I asked, since an RTF document that I've written in Atlantis, behaved strangely in an Adobe DTP program that a collegue of mine is using.
I don't know exactly what caused the strange behaviour in Adobe. I pasted a lot of text from webpages in the RTF doc. Maybe some invisible HTML formatting ended up in the RTF doc?
From a recent Atlantis Tip (at startup), I now understand that you can paste clean, unformatted text into a document with Ctrl-Alt-Insert. I didn't use that. I simply Ctrl-Ved. I guess this caused the problems.
Overcast
