Sending documents by e-mail client Opera 7.50
Guest
Post by Guest »
First let me say that I newly registered my Atlantis program, and it seems to fit perfect in my old 500 MHz laptop. I use the program mainly to translate documents from English to Norwegian, and visa versa. The problem I have is that I’m not able to send the documents, using the «Send documents by e-mail» button. I’m using the excellent Opera M2 mail client.
Can you help me finding a way out of it? I really think Opera (version 7.50) is the best browser/e-mail client there is, so I really hope it’s possible to do something about it.
Another thing; is it possible to change between languages with hot-keys? To always use the mouse slows me down and takes concentration away from the text.
This is really minor flaws, but anyway a bit annoying.
The Email features of Atlantis allow to send email through the default "Simple MAPI"-compliant email client on your PC.
As I know, Opera is not MAPI compliant. If it is true, Atlantis could not send email messages through Opera. I am sorry.
About switching between languages. I am not sure that you need exactly this. But you might find the following information useful:
If you need to type texts in multiple languages, you could install the keyboard layouts for these languages (Windows Control Panel > Keyboard > Input Locales). In your case, you could have two keyboard layouts: "English" and "Norwegian". Windows allows to switch between the installed keyboard layouts with a hot key (Alt+Shift, or a similar hot key). When you need to type English text in Atlantis, you could switch to the English keyboard layout. Any new typed text would be automatically marked with the English language in Atlantis. When you need to type Norwegian text, switch to the Norwegian keyboard layout. Any new typed text would be automatically marked with the Norwegian language in Atlantis.
If you meant a different thing, please explain with more details.
