Mathematical Symbols?
Is there a way to type the symbol meaning "less than or equal to"?<br><br>The Symbols box allows for "greater than," "less than," and "greater than or equal to."<br><br>Thanks for any assistance.
Re: Mathematical Symbols?
As I know, the Symbol font has such a character (ASCII code: 163).
Please advise how to do it. Thank you.
Choose the "Insert | Symbol..." main menu command.<br>Select the "Symbol" typeface from the font list.<br>Double-click the desired symbol.
I'm sorry for any confusion I may have caused. Please tell me how to use ASCII code:163. Because the symbol represented by ASCII code:163 doesn't appear, I can't double click on it. Thank you.
When the "Insert Symbol" dialog is active, the code of the currently selected symbol is displayed by the status bar of Atlantis.
