Will Atlantis support HTML within the next 12 months?
dosdan
Post by dosdan »
I did a search on "metafile" in the forum and found that the IE to Atlantis no-graphics problem was mentioned as far back as 10th June 2001. At the time the reply given was that Atlantis did not support HTML yet. The wording of that reply and others to do with metafiles led me to believe that it was a peculiarity of IE but I find I can't paste embedded graphic elements in webpages from either Mozilla Frefox 0.8 or Opera 7.20 either. (I know you can do individual cut-&-pasting on each graphic.)
1. Are there any web browsers that produce an RTF format that Atlantis can paste correctly?
2. Can I expect this to be possible if Atlantis eventually accepts HTML formatted files, and, if so, how high on the To Do list is this?
Pasting HTML text from the clipboard is on the Wish List. But regrettably I cannot give any timetable.
