Window shifts when typing
John Stafford
Hi: using latest beta. Screen res 1024*768 with Clip Folder open and zoom at 120%. This gives me an ideal screen size for typing. When I type to the end of a line, the screen shifts left such that I lose text visibility at the beginning of lines. And when I type at the start of a line, the window shifts right again so that text at the end of lines is cut of by the Clip Folder window. At this zoom level, both vertical margins are visible so all text should remain centred on the screen. However, that doesn't happen unless I close the Clip Folder window. Ideally, if I can see both vertical margins, the page should remain centred on the screen without having to use the horzontal scroll bars, even with the Clip Folder window open. Hope I've described this correctly. Thaks. John
