booklet printing error Exception: Division by zero
Hi, I tried to print a booklet. I followed the instructions in the Help file. However, no matter what combination of pages I use, when I try to print, I get the error message: Exception: Division by zero. Has anyone had this experience. I followed the help file exactly and set up my printer. Thanks.
Thanks, zippy
Re: booklet printing error Exception: Division by zero
Greetings--zippy wrote: Hi, I tried to print a booklet. I followed the instructions in the Help file. However, no matter what combination of pages I use, when I try to print, I get the error message: Exception: Division by zero. Has anyone had this experience. I followed the help file exactly and set up my printer. Thanks.![]()
If at all possible, could you please send the document you are trying to print as a booklet to comment@rssol.com ?
With a detailed description or screen capture of your print settings
a) in the Atlantis Print dialog,
b) in your printer's dialog.
Also which printer are you using (make, model)?
Does it print to the top or underside of pages (pencilled cross test)?
division by zero
Thanks, zippy
booklet printing divided in half
Well, this is what I meant by dividing the paper in half.
BEFORE clicking on the booklet printing button, I created the file with the landscape mode and divided the page into two colums.
So, the printing booklets command had nothing to do, since the document was ALREADY divided into two columns.
When I created the document in the more normal mode of portrait mode and using the whole 8 1/2 x 11 1/2 page, and THEN asked to print it in booklet form, the program worked correctly, except the print was too small.
I hoped this explains it better.
Thanks, zippy
