Lines
Guest
Lines
Post by Guest »
I have noticed on the updated beta if I type (*Lin) a different amount of lines appear. If I type (**Lin) more lines appear. Is this a bug.
As said on the Betatesting News page (build b02):
The Auto Insertion feature of the Atlantis Clip Library has been improved. Now you can type not only clip names directly in the document but also names of clip folders. For example, if you want to insert a clip from the "Images\Lines" clip folder, you could type two asterisks in your document, then type the first three letters of the "Lines" folder name. A list of all the clip folders whose names begin with the same 3 letters will automatically pop up:
After this you can select the desired clip folder, and press Enter. Atlantis would display a list of clips contained by the selected clip folder:
Now you can select the desired clip, and press Enter again to insert it to your document.
"*lin" displays all the clips whose names begin with "lin".
"**lin" displays all the clip folders whose names begin with "lin".
The "Lines" clip folder contains clips whose names do not begin with "lin". For instance, "Classic", "Eyes". This is why you have different lists in these two cases.
