Delete documents
Guest
Delete documents
How do I stop documents from loading on start up. Also how do I delete old documents.
Guest
Re: Delete documents
<br>
By the way my documents are up to 70+ but I have no documents saved Im puzzled. how do I get the documents on the document bar back to 0?Guest wrote:<br>How do I stop documents from loading on start up. Also how do I delete old documents.<br>
Atlantis reloads documents if the Reload Open Documents On Startup option is checked (the Tools | Options..., the General tab).<br><br>>How do I get the documents on the document bar <br>>back to 0? <br><br>Not sure that understood what you mean...<br>If you ask how to close currently open documents, use the File | Close or File | Close All command.<br><br>>Also how do I delete old documents.<br><br>Use your Windows Explorer to delete document files.<br>
Max_Quordlepleen
- Contact:
<br>
<br><br>Try this:<br><br>Tools>Options>General, and uncheck "Continuous numeration" See if that helpsGuest wrote:<br><br>By the way my documents are up to 70+ but I have no documents saved Im puzzled. how do I get the documents on the document bar back to 0?<br>
Salaam alaikum, noho ora mai
guest
Thanks Max its done the trick. Have you any idea why atlantis starts up slow compared to how it used to. I have had to format my hard drive and reinstall all my programs, does this help you to work it out? thanks.
Max_Quordlepleen
- Contact:
<br>
<br><br>I have no idea why Atlantis has gone slow on you. Mine is as fast as ever, faster now that I've killed the splash screen. I'm sorry, but are you sure you haven't installed anything else that might be slowing you down?guest wrote:<br>Thanks Max its done the trick. Have you any idea why atlantis starts up slow compared to how it used to. I have had to format my hard drive and reinstall all my programs, does this help you to work it out? thanks.<br>
Guest
<br>
<br>Do you think if I uninstalled Atlantis and reinstalled it might do the trick?Max_Quordlepleen wrote:<br><br><br>I have no idea why Atlantis has gone slow on you. Mine is as fast as ever, faster now that I've killed the splash screen. I'm sorry, but are you sure you haven't installed anything else that might be slowing you down?<br>
Max_Quordlepleen
- Contact:
<br>
<br><br>It can't hurt,as long as all your personalised Atlantis settings are backed up first.I know this is a real dumb question, but when was the last time you defragged?Guest wrote:<br><br>Do you think if I uninstalled Atlantis and reinstalled it might do the trick?<br>
guest
Today Max. I have uninstalled and reinstalled, trying the same again. Atlantis is running so slow I feel as though I cant use it im waiting forever for it to load.
guest
It is only Atlantis what is running very slow all my other programs are running as normal. how do I find if there is a conflict with another or other programs?
Max_Quordlepleen
- Contact:
<br>
<br><br>Why not Ctrl-Alt_Del, to see what's running, and then shut everything non-essential down. Start Atlantis, and see if it is faster with everything else off. Then try adding the other app.s listed in the "Close Program" box one at a time, until you find the problem.guest wrote:<br>It is only Atlantis what is running very slow all my other programs are running as normal. how do I find if there is a conflict with another or other programs?<br>
Guest
Thanks Max, tried what you sugested but still no change. I run Atlantis without the splash screen but it loads the same speed with or without the splash screen, I'm wondering if Atlantis or whatever<br>is not recognising the no splash instuction. just a thought. Its the slowest running program on my computer. Have you or anyone else any further ideas befor I fall asleep waiting for Atlantis to start...Only joking yawn..
guest
<br>
<br><br>It seems the slowing down of Atlantis could be due to the customisation of Atlanis's tool bar. Any other users had the same problem???Guest wrote:<br>Thanks Max, tried what you sugested but still no change. I run Atlantis without the splash screen but it loads the same speed with or without the splash screen, I'm wondering if Atlantis or whatever<br>is not recognising the no splash instuction. just a thought. Its the slowest running program on my computer. Have you or anyone else any further ideas befor I fall asleep waiting for Atlantis to start...Only joking yawn..<br>
You could easily check this. Just delete the Atlantis.ats (Atlantis Tollbar Settings) file from the home folder of Atlantis.<br>If Atlantis still works slowly, there is another reason.<br><br>By the way, do you have an antivirus utility working on background?<br><br>Could you tell the CPU clock (MHz) of your computer?
Max_Quordlepleen
- Contact:
D'Oh! I should have though about AV apps. You don't use that bloated crapware Norton do you? McAfee's not much better as a resource hog from what I hear.
Guest
Norton seems alright to me Max. Any other sugestions Or are all programs apart from Atlantis CRAPWARE. ??? ??? ???
Max_Quordlepleen
- Contact:
<br>
<br><br>Norton is famous for being a resource hog. One MVP whose opinion I valu said "Norton does not have clients, only victims". For good, light AV app.s, try AVG from grisoft.com, or eTrust EZ antivirus from ca.com I used to have Norton installed, md I know how it can slow things down. Apparently pc-cillin is also a good av appGuest wrote:<br>Norton seems alright to me Max. Any other sugestions Or are all programs apart from Atlantis CRAPWARE. ??? ??? ???<br>
Guest
<br>
<br>Oh. by the way Max I use Norton System Works 2000, any comments? Thanks again.Guest wrote:<br>I value your response and help very much Max. Thanks.<br>
