View | Clip Library
luha
View | Clip Library
Post by luha »
"There is now a new 'View | Clip Library' command in Atlantis."
No there isn't - not in my Atlantis. When I click "View" I see a list ending with "Header and Footer", "Clippy Bank" and "Format Palette". I can view the Clip Library with the button, though. And a hot key. But what is wrong?
Most new commands are automatically available in the default menu of Atlantis (those who make a clean install, have the default menus and toolbars). But Atlantis never adds new commands to the main menu if you customized it.
You could choose the "Tools | Menus..." command, and click "Restore Default".
Alternatively you could manually add any new command to your customized menu through the same "Tools | Menus..." dialog.
The same regarding toolbars. Atlantis never adds new commands to your toolbars if you ever customized them.
