error message?
dicknu
error message?
Post by dicknu »
With both Ocean Mind and Nova, I now<br>get this message when I click on the "home"<br>icon to call up "Atlantis on the Web."<br><br>    "Error launching Web Browser"<br><br>Any ideas of what I've done to cause that?<br><br>dickn'<br>
Re: error message?
This means that Atlantis was not able to launch your default Web browser. Probably no application is associated with the htm file extension.
dicknu
Re: error message?
Post by dicknu »
Ahh!  You are correct.  That is the first<br>thing that I checked. Association was okay.<br>And other applications call it fine. <br><br>I'll let you know if I can find what the <br>problem is.<br><br>Thanks for listening!<br><br>dickn'<br>
Re: error message?
There might be another reason. Maybe you deleted the temporary folder of Windows (as a rule, C:\Windows\Temp\)? Is this folder available/"write-permitted"?
