Address Book: importing contacts
John Stafford
Post by John Stafford »
Hi: I was wondering if there was a convenient way of importing contacts to the Atlantis address book from csv or other text files files?
Re: Address Book: importing contacts
John Stafford wrote: Hi: I was wondering if there was a convenient way of importing contacts to the Atlantis address book from csv or other text files files?
Hi, John!
It all depends on the format of the entries in your CSV file.
Sometimes a (few) simple search and replace operation(s) will do the trick. This can be done in Atlantis.
Sometimes you might need to find a proper search and replace pattern using regular expressions and a text editor with support for regular expressions.
If you sent or posted a few sample entries as they can be found in your CSV file, we could be more specific.
Of course, do not send actual entries. Simply create a few copycat entries for demo purposes only.
