Has anyone experienced the same? What is the reason? [/i]
Templates
Templates
Some of my templates in rtf-format seem to mutate
At the end of the document the content of header and footer is shown. If I change the template and save it again (save special ... as template) it mutates again. By saving it on another way (save as/F12) it works.
Just call me the Prince
Re: Templates
Hi, Prince!Prince wrote: Some of my templates in rtf-format seem to mutate ;) At the end of the document the content of header and footer is shown. If I change the template and save it again (save special ... as template) it mutates again. By saving it on another way (save as/F12) it works.
What exactly do you mean by "mutate"?
Could you be more explicite as to what is exactly happening?
Well, the contents of header and footer are placed not only in their places but also at the end of the text. I will send a sample to support@rssol.com.
Please simply redownload the latest Setup file of Atlantis. It includes a fix.
