COD document
pelado
COD document
Post by pelado »
I am having a lot of headache with documents COD.
I have 2 documents of the type COD and I don't get to open, I already tried all them possible password. I need some password that can open these documents...
Can it happen of the password to be correct and not to open because of the version of ATLANTIS?
Thankful
Guest
Post by Guest »
Never seen that a cod-file refused to open when the password was correct. Only problem is normally that I tend to forget the passwords.
This has nothing to do with the version of your Atlantis. The password is incorrect.
Note that the Atlantis passwords are case-sensitive ("Atlantis" and "ATLANTIS" are not the same).
pelado
Post by pelado »
In case I don't remind the password doesn't he/she have way of reading him/it what there are in the files?
Atlantis could not open a COD document if you do not have a correct password.
When you create a COD file, Atlantis displays the following warning:
Attention! Atlantis uses a very strong type of encryption which cannot be cracked. Safeguard your password very carefully. If you lose a document password, you will not be able to open that document and access the information inside. Please be cautious!
