Full screen & scroll bar? Also backup question
Laren
Post by Laren »
Is it possible to have the right-hand scroll bar showing (but nothing else) when in full screen mode (F9)?
How can I set Ocean Mind so that every time I save a changed version, the unchanged version is automatically backed up as "filename.bak" in the current directory. I rarely need more than one backup as I save frequently when working, and I want all backups in the same directory as the original.
Thanks for any help.
Sandman
I am sorry but none of this is possible.
No scrollbars are displayed under the Full Screen mode. Otherwise it would not be the Full Screen mode. You could use the wheel of your mouse for scrolling the document window.
Atlantis Ocean Mind 1.5 (and higher) saves backup files to the special Backup folder. Choose "Tools | Options, Load/Save, Backup Files" to adjust the Backup Options of Atlantis.
