PDF CONVERTER
DELWATT
PDF CONVERTER
Post by DELWATT »
:D I noted on the forum that a PDF converter is wanted for Atlantis. This is to let all know that GLENN ALCOTT has made one that will read RTF and convert to PDF. The same BATCH routine will also convert PDF to text.
The program is called PDF Converter
The Web Site is ==> www.galcott.com
This batch routine is a WINDOWS application and is designed for Windows 95/98/NT/ME/2000/XP. It allows you to download the application in the ZIP format which can then be Un-Ziped which results in a README file and a SETUP.EXE. Once you run SETUP.EXT from explorer or even under a DOS WINDOWS, it sets up the small utility in what ever sub-directory (folder) that you desire and puts an ICON on your desktop.
This trial version is fully opeational but requires a registeration number to make the NAG note go away.
The utility will convert your many RTF files into PDF in the batch mode and then get out of the way.
Downloading takes about 5 minutes with a slow modem (1.5 Meg).
Glenn Alcott takes PAYPAL and a host of other payment plans. The cost of the program is $24.00
Other programs that he has produced are POWER EDIT (which even saves as an PDF), SUPER EXPLORER (views graphics and converts graphics as well as a two window file compare), Printer Directory, Directory Compare, Super Text Search, and Font Look.)
I have two of his programs and they work without fuss or pain. The PDF Converter makes a nice addition to Atlantis. It is not part of Atlantis and can be working in it's own window at the same time you are editing inside of Atlantis. :D
D.J.Watt -- Sedona,AZ
PDF CONVERTER
DELWATT wrote: I noted on the forum that a PDF converter is wanted for Atlantis. This is to let all know that GLENN ALCOTT has made one that will read RTF and convert to PDF. The same BATCH routine will also convert PDF to text.
Hi!
There are free PDF converters at the following Web Site pages:
- Go2PDF at http://www.go2pdf.com/product.html
- Easy PDF at http://www.visagesoft.com/easypdf
- PDFMoto has a free version at http://www.pdfmoto.com
PDF Drivers/Converters
Hi!
Another good PDF driver/converter can be found at http://www.pdf995.com
Prince
Post by Prince »
PDFMailer was my chose. OK, there is some advertising in the head of the page, but it works on my Win98-installation at home where go2pdf fails.
Just call me the Prince
