| View previous topic :: View next topic
| Author
| Message
BuffyBot
| Posted: Wed Nov 19, 2003 2:54 pm Post subject: Two ideas
| Replace Style
This would allow a user to overwrite one style with another, in a situation where a user didn’t want a style to convert to normal by simply deleting it. (e.g., convert all H3 paragraphs to H2 paragraphs before deleting the H3 style)
Custom link as menu item
Now that Atlantis has customizable menus, it would be very useful be able to add a custom URL or two to the menu that would trigger a website of our choice. (e.g., to be able to add a link like www.thefreedictionary.com or a translation site or other word-processing oriented sites)
| Back to top
| Posted: Sun Nov 23, 2003 5:36 am Post subject:
| About styles.
Let’s suppose that your document contains many paragraphs formatted with “Heading 3”. If you want to format these paragraphs with “Heading 2”, you could choose “Format | Style...”, and change the base style for “Heading 3” to “Heading 2” (ie specify that “Heading 2” is the base style for “Heading 3”). This can be done through the “Format | Style, Modify” dialog. Alternatively Drag & Drop can be used in the “Format | Style” dialog: simply capture the “Heading 3” style with the mouse, then drop it onto the “Heading 2” style.
Then close the “Format | Style” dialog. Then open it again, and delete the “Heading 3” style. All the paragraphs initially formatted with “Heading 3”, would be automatically associated with the base style of the obsolete “Heading 3” style (ie with "Heading 2").
| Back to top
BuffyBot
| Posted: Wed Dec 03, 2003 3:45 am Post subject:
| | admin wrote: |
Thanks for explaining this.
| Back to top
Did you know that ...
Ctrl+PgUp moves the cursor to the beginning of the previous page. |
| Powered by phpBB |
