Atlantis 'Options...'
Van
Post by Van »
I noticed today, that even though I checked the box 'Always Show Full Paths' under the 'General' tab, the header in Atlantis only says <br><br>[C:\My Documents\...\Silly stuff :-/.rtf] <br><br>instead of <br><br>[C:\My Documents\Docs\Silly stuff ;).rtf]<br><br>So, what's 'full path' if not the second version I've written here?<br><br>Go figure, ::)Van
Out with it...
Re: Atlantis 'Options...'
Van, the Full Path does not mean that any filename will contain the names of all the folders from the folder tree. Your filename might be very long. Such filename could not be used for the main menu commands. When your filename is too long, Atlantis replaces some folder names with dots.<br><br>When the Show Full Paths option is off, Atlantis might do not display folder names and disk letters at all.
Van
Post by Van »
Well, thanks for telling me anyway, at least now I can stop shouting at my monitor... "What's this, I said full path ???" ...every time I open a doc<br><br>It was making me a bit hoarse already... ;) <br><br> :D Van
Out with it...
Van
Create Backup Files option...
Post by Van »
I don't usually use this option because I find that my folders are cluttered up with '.bak' files, making these folders difficult to survey, finding stuff in them 'by hand' ...<br><br>How about the possibility of selecting a special destination for these .bak files, their own "Atlantis.BAK" folder where they would reside untill needed. I don't like them being mixed among my normal documents - .rtf<br><br>This would work similarly like the selection of the default folder for saving docs that we have now.<br><br>One more query.<br>The 'Safeguard' feature doesn't create any files on disk that I noticed, it likely only demands a bit more of computing resources (disk space?) to recover from crashes. Am I right? And only during the time that Atlantis is open? Not sure about the exact mechanism of this option...<br><br>Van
Out with it...
>How about the possibility of selecting a special <br>>destination for these .bak files<br><br>It might produce numerous conflicts. You might open several documents with the same name but from the different folders. All these documents would have the same corresponding .bak file.<br>This is a general practice.<br><br>About the 'Safeguard' feature. The safe copies are saved to the "C:\Windows\Temp". Though you do not need this info in order to use this feature. Atlantis would restore documents from these safe copies itself. You should not care about this at all. Just enable the Safeguarding. Atlantis will do its best.
Van
Post by Van »
Quote: <br><br>"Though you do not need this info in order to use this feature. Atlantis would restore documents from these safe copies itself. You should not care about this at all. Just enable the Safeguarding. Atlantis will do its best."<br><br>Then why make it an option to checkmark, why should anybody not want this safeguarding as is implied by the fact it is optional ... why not 'let Atlantis do its best' ... there must be something to it if some people according to you would prefer not to have this feature ... else you wouldn't make it an option ... <br><br>I myself prefer understanding things though I am aware I irritate people throughout my life with such prying into things that most people just take at face value in the monkey-like fashion.<br><br>Van<br><br>
Out with it...
>there must be something to it if some people <br>>according to you would prefer not to have this <br>>feature <br><br>Right. If your computer is too slow or/and your hard drive has not enough free space, you might wish to disable this feature. As well as if you do not need the "Click & Type" feature, you can disable it.<br><br>Different people - different tastes... But you have a choice...<br><br>By the way, the safeguarding is activated by default.
