opening Form Docs
nomad200
opening Form Docs
I've previously made some docs using Word97; these are "form docs" with vertical & horizontal columns; note - not an Excel doc. When I open them with Atlantis, although all the nomenclature is shown, none of the columns are shown. Is there a way to open docs so that WYSIWYG? In any case, Atlantis gets high marks for fast execution and formatting options!
Re: opening Form Docs
Hi, nomad200!nomad200 wrote: I've previously made some docs using Word97; these are "form docs" with vertical & horizontal columns; note - not an Excel doc. When I open them with Atlantis, although all the nomenclature is shown, none of the columns are shown. Is there a way to open docs so that WYSIWYG? In any case, Atlantis gets high marks for fast execution and formatting options!![]()
Most likely your DOCs contain tables and/or frames. These functions are currently unsupported by Atlantis. This is why your "columns" don't display as intended in Atlantis.
Keep using Atlantis for what it currently can do. You soon won't be able to do without it!
