Pages inserting, deleting, order
PaV
Post by PaV »
I would like to have control over whole pages of text globally. For example to insert a blank new page between two existing pages, to delete whole pages, to change their order. It would be similar to writing a book with chapters or sections. Also if i want to add more text it automaticaly makes new pages if necesarry and doesnt break up the layout of other sections. I know it can be achieved by using copy-paste or pressing enter many times etc. or by using separate documents, but i would want to have it as one document. Maybe something like this already exists in Atlantis ? If so, please let me know. Thank you for reading.
Re: Pages inserting, deleting, order
PaV wrote: I would like to have control over whole pages of text globally. For example to insert a blank new page between two existing pages, to delete whole pages, to change their order. It would be similar to writing a book with chapters or sections. Also if i want to add more text it automaticaly makes new pages if necesarry and doesnt break up the layout of other sections. I know it can be achieved by using copy-paste or pressing enter many times etc. or by using separate documents, but i would want to have it as one document. Maybe something like this already exists in Atlantis ? If so, please let me know. Thank you for reading.
Hi, PaV!
1) To insert a blank new page between two existing pages, you can either
a) Place the mouse cursor at the bottom of the first page, then press CTRL+ENTER twice.
b) OR place the mouse cursor at the bottom of the first page, then
- insert an odd page section break if you are at the bottom of an odd page,
- insert an even page section break if you are at the bottom of an even page.
2) To delete the whole current page, you have to
a) select the current page by pressing Ctrl+K, G,
b) then press the DEL key to delete the whole page.
3) To delete several consecutive pages, you have to
a) select the target pages with mouse and/or keyboard,
b) then press the DEL key to delete the selected pages.
4) To change the order of pages, you can
b) then press CTRL+X to cut the page to the Windows Clipboard,
c) then insert the contents of the Windows Clipboard (i.e. the page you just cut) back into your document at any appropriate location.
PaV
Post by PaV »
Thanks a lot Robert!
