Slow start up
Guest
Slow start up
Post by Guest »
Since downloading the new version the start up rate has dropped considerably, any ideas on how to get it back to its original start up speed?
Guest
Re: Slow start up
Post by Guest »
<br>
Guest wrote:<br>Since downloading the new version the start up rate has dropped considerably, any ideas on how to get it back to its original start up speed?<br>
<br>I should say the start up speed of Atlantis. Sorry for any confusion.
Re: Slow start up
The start up speed of Atlantis is absolutely the same as before.<br><br>If you checked the Reload Open Documents On Startup option (the Load / Save group of settings), Atlantis might reload the documents that were opened when you were closing Atlantis.
Guest
Re: Slow start up
Post by Guest »
<br>
admin wrote:<br>The start up speed of Atlantis is absolutely the same as before.<br><br>If you checked the Reload Open Documents On Startup option (the Load / Save group of settings), Atlantis might reload the documents that were opened when you were closing Atlantis.<br>
<br>I have unchecked what you have said but no change. Atlantis used to open imediately but now takes a full seven seconds to respond.
Re: Slow start up
Again, Atlantis works as it worked before.<br><br>Please check which changes you made to your system settings.
