internet explorer
zippy
internet explorer
Post by zippy »
Do you have to have internet explorer installed to use Atlantis?
Most probably that you would not be able to use the Help system of Atlantis if you do not have MS Internet Explorer. Also the "Help | Check for Updates" menu command of Atlantis might be disabled. But you could still use Atlantis even if you do not have MS Internet Explorer.
