I was working on a template for cd-covers (don't know if that makes a lot of sense, but I saw something similar with the OpenWriter) and saved it as a template in cod-format. Shockingly I wasn't asked for a password when saving and also when opening.
You might think it as a weird thing but following that there is one (just one) way to open a cod-file without password. But therefor it has to be saved first as a template.
And, yes, you can create a cd-cover with Atlantis. Everything else would be more a surprise.
Cod-files & templates
Just call me the Prince
First, Atlantis could not open a COD file if you do not provide it with a correct password. No backdoors are possible. But there was another problem. When you saved a document as template, Atlantis simply ignored your choice of the target document format. A newly created document template always had the format of the source document.
A fix included to the latest build. Thanks.
