Hot Key
Hot Key
Post by 1953 »
We now have a hot key to re-open from system tray how about a hot key to close Atlantis.
Guest
try
Post by Guest »
Try Alt + F4
standard windows shortcut
You can close any application by pressing Alt+F4.
But the "Exit" command was missing from the list of the Atlantis's commands. Now it is available through the "Tools | Hot Keys", "Tools | Toolbars", and "Tools | Menus" dialogs. If you associate the "Exit" command with a hot key, you could use this hot key for closing Atlantis minimized to the system tray.
1953
Post by 1953 »
admin wrote: You can close any application by pressing Alt+F4.
It would be better if we could as an eg. use ctrl+1 to close to system tray and ctrl+1+1 to re-open from system tray. in other words hold down ctrl and double press 1. This would cut out hundreds of hot key combinations. :roll:
I am sorry but such key combinations are impossible in Atlantis.
