Menus command
Guest
Menus command
Post by Guest »
The new menus command is very welcome. In the customize main menus box the list with, file,edit,view,insert,format,tools,help, are jumbled up and difficult to read. Also if a command is deleted has it gone forever, or can it be put back if needed?
Guest
Menus command
Post by Guest »
[quote="Guest"]
The new menus command is very welcome. In the customize main menus box the list with, file,edit,view,insert,format,tools,help, are jumbled up and difficult to read. Also if a command is deleted has it gone forever, or can it be put back if needed? Could it be possible to remove from the toolbar one of the items mentioned, eg. file or help?
You can always add the desired commands to your menu (use the "New command" button of the "Tools | Menus" dialog).
I am sorry but you cannot remove the menu top-level items (File, Edit, View, Insert, Format, Tools, and Help).
I do not understand what you mean. The main menu is displayed in the "Tools | Menus" dialog in the same way as it is displayed in the main window of Atlantis.
Guest
Post by Guest »
admin wrote: You can always add the desired commands to your menu (use the "New command" button of the "Tools | Menus" dialog).
Not on my computer windows 98.
File,Edit,View,Insert,Format,Tools,Help. Are a little difficult to read File is a little lower then the rest, and the end letter/letters are missing off each name. It is as though the names of each one are too close together.
Guest
Menue
Post by Guest »
A picture has been e-mailed to you.
The latest build should display menus on your system properly. Thanks.
Guest
Post by Guest »
admin wrote: The latest build should display menus on your system properly. Thanks.
Ok know :D
